4/27/2018 11:34 AM | |
Posts: 4 Rating: (0) |
Hi, as I am in a similar situation like the requester before I would like to ask if anyone has practical experience with PWM output frequency of transistor outputs of LOGO. How many Hz are realistically achievable? And is the ouput frequency depending on the complexity of the application e.g. how many function blocks are used? Unfortunately I currently only have LOGOs with relay outputs here. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 4/27/2018 2:00:25 PMNew subject after splitting |
5/11/2018 6:19 AM | |
Joined: 6/19/2017 Last visit: 9/6/2024 Posts: 8175 Rating: (173) |
New question published by vin agu is split to a separate thread with the subject Need to use LOGO to control an Induction Furnace between 4KHz and 8KHz. Best regards |
5/11/2018 6:21 AM | |
New question published by vin agu is split to a separate thread with the subject Need to control an Induction Heater between 4KHz and 8KHz analog inputs and digital outputs with Logo. Best regards |
