6/6/2018 6:06 PM | |
Joined: 3/15/2018 Last visit: 12/2/2024 Posts: 25 Rating:
i really need urgent help I'm trying to simulate The reading and writing of PLC tags using OPC clint i'm using OPC Scout V10 and Simatic Manager v5.5 sp4 and Simatic Net v8.2.1 i configured the station and imported the XDB file in station manager and downloaded the configurations but i still get invalid and bad signal i also tried this way : If your STEP 7 (SIMATIC Manager,...) and the OPC server are on the same PC try the following:
from this post : https://support.industry.siemens.com/tf/ww/en/posts/how-to-browse-items-in-opc-server-opc-simaticnet/5101/?page=0&pageSize=10#pagetop i did all steps perfectly but i have problem when i try to do the last step and download the PLC from NetPro you can see it in attached pictures in zip file Regards Attachmentopc1.zip (201 Downloads) |
6/10/2018 11:49 AM | |
Hello Murof Thank you for your response find the attached zip file containing pictures with all the steps i followed and configurations that i did. Thank you again Attachment1.zip (222 Downloads) |
6/17/2018 12:11 AM | |
Dear Murof I'm very thankful for your continuous support and quick response :) as you asked and showed above find attached screenshots of station configuration and diagnostic window. Regards MOHAMMED ABUBAKER AttachmentUntitled.zip (196 Downloads) |
1/30/2020 10:28 AM | |
Posts: 1 Rating:
Hello, please try to check in PLC device properties and check "permit PUT/GET communication.....(OPC, HMI,...)" |
