6/19/2010 2:41 PM | |
Posts: 31 Rating:
chrisB_isi i want to clarify something maybe this is the one i am looking for and you are the right person to ask...I have only very basic knowledge in scripting i hope you can help me..thanks! Correct me if I'm wrong in my understanding in your post. A bit is set if there is someone who logged in and reset if none? Can you please discuss more detailed by answering these question. 1. Using Scheduler: Let say I will put a new job NAME CurrentUser and EVENT Change user and in the Function List..is this were will i choose the script name or script title from the drop down list that was been added in the Script folder(script that you made)? 2. What are the tags that are involve in your script that will i add in the taglist? 3. LOGIN_NotLoggedIn is this the bit monitor if there is someone who is logged in? 4. In System/LOGIN_NotLoggedIn what is that System?is that a sub folder of TAG? 5. How will i know and check if the script that i made is correct?i tried the microsoft Script Debugger but i dont know why it is not executing when i choose to run with script debugger. (I already installed from microsoft site and there is no other debugger is currently intalled. Splitted from Display Current user that is logon. |
6/20/2010 8:03 PM | |
Posts: 103 Rating:
Hi rlyean, Please refer the similar script mentioned in your another thread regarding the similar issue, /tf/WW/en/Posts/45094#top In this script as you hadasked the details will brief you that there are total 3 tags used 1. Internal Tags - Username(String), password(String). 2. External Tag - Loggedin(bit) this external tag loggedin will giv you the status if no user is logged in. I wish with this brief glimse over the script will help you implementing script and diagnosing the same well. I wish you best of luck Thanks |
