1/5/2011 6:27 PM | |
Joined: 9/6/2008 Last visit: 3/29/2024 Posts: 134 Rating: (16) |
at first please do not post the same qouestion at to many posts ! ( moderator will be come mad ) now thinks one by one . if your engine is aircooled then perhaps you dont need to use a pt100 sensor ,exept if you plan something else ( display etc) . you could find some thermostats that they can be fit in the zylinder head of the engine and they give you a no/nc contact free and you conect it to the logo.( like the one they use for thesmall transformers -welding machines etc) http://www.thermodisc.com/productdetail.asp?ProductID=80 for the batery voltage.if you want to mesure the voltage you need a converter from 12or24 vdc to 0-10v. http://www.luetze.ch/Suppression-Technology-Interf.14+M5a585329a6c.0.html dowload "interface technology "( page 1-37) but you could find and some other solutions http://www.bernini-design.com/ they have a batery chargher with an aux contact. the price for the am pt100 must be about 100 euro+/-.a converter from pt 100>0-10v is cheaper. if you havean analog input to spend. best luck. |
http://electrotech-techblogg.blogspot.gr/ |
