11/30/2018 11:19 AM | |
Joined: 2/10/2015 Last visit: 6/20/2023 Posts: 1 Rating:
Hi, I'm considering to use this library to reduce vibration of a big gantry structure, moved by 2 servomotors, one in each side. As I'll position them synchronized to a virtual axis, if I apply the Simotion vibx filter in each real axis, would it be effective or setpoint coming from virtual axis will not be "corrected" by the filter? I read in the documentation that it can't be applied to a virtual axis. Or do you think it would be better to use the Sinamics vibx in each real axis? Thanks in advance! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/10/2018 12:27:54 PMNew subject after splitting |
