4/25/2012 10:00 AM | |
Joined: 4/22/2010 Last visit: 1/15/2025 Posts: 5697 Rating: (715) |
Hello, Attachmentlib.zip (677 Downloads) |
Last edited by: Marcjan at: 4/25/2012 10:11 AMChanged zip Last edited by: Marcjan at: 4/25/2012 10:05 AMProblem solved? |
4/25/2012 10:17 AM | |
Posts: 37 Rating: (2) |
Thanks for reply. I did what you said. Yes it works. But i like to do some things differant. I want to use as a ladder element of this program part. You can check it at this video on 01:50 http://www.youtube.com/watch?v=aUILkF4aI30 Do you have any idea how to create some blocks like that ? It seems somebody have created these blocks in library they use at this video. Best regards. |
4/25/2012 2:04 PM | |
Nobody knows how to create library blocks just like in video ? Video shows a wiper control block. That block has inputs and outputs. Tia Portal experts ?? :) |
4/25/2012 3:52 PM | |
I want to put some ladder program parts in to a block and save it in library. Long ladder diagram will be in small box and box will have inputs , outputs. I see this kind of block at this video ( wiper block ). http://www.youtube.com/watch?v=aUILkF4aI30 I just want to know hot to create it. If Siemens put this video , that means everybody can do same thing. But how ? Best regards. |
4/25/2012 3:57 PM | |
Joined: 7/7/2010 Last visit: 1/24/2025 Posts: 15558 Rating: (2467) |
Create either your FC or FB. Copy your ladder logic. Add your header inputs/outputs. Revise your ladder logic to use the internal tags. Save, Compile, and drop into your logic to test. Nothing fancy other than creating the FC/FB. |
science guy |
5/1/2012 10:23 AM | |
Thanks for kind replys. I finally did it. Best regards.. |
