4/3/2024 2:01 PM | |
Joined: 4/26/2012 Last visit: 4/25/2025 Posts: 1629 Rating:
Hello, ok this LINK will help you better. Note You should always test on the physical HMI, for example, it won't work on the simulator. good luck.
Last edited by: rdoliveira at: 04/03/2024 14:05:38edit Last edited by: rdoliveira at: 04/03/2024 14:06:45edit Last edited by: rdoliveira at: 04/03/2024 14:07:29edit Last edited by: Jen_Moderator at: 04/05/2024 05:05:25Link optimized. "Always make a backup before performing any tests |
