2/25/2009 3:37 PM | |
Hi Jaapie I didn´t understand your problem. You can create tags in the tag management and then you can use this tags in a VBS-script like a defined variable. Also you can write a block for the PLC, were you get and set tag by using the BSEND / BRESV - block and Raw Data Type in WinCC. This rawdata you have to dedoce with a script in WinCC. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
