9/12/2017 9:51 AM | |
Joined: 10/24/2011 Last visit: 1/23/2023 Posts: 71 Rating:
Hello saeed, I think isn´t problem ... u can read your EPROM module and program to EEPROM module Proceed as follows when working with S5 memory modules : 1. Switch on your device. 2. In your STEP 5 software, start the function Administration > Edit EPROM. 3. With the type label pointing to the rear, insert the SIMATIC S5 Memory Card or the S5 adapter into the Memory Card interface and then the S5 memory module. 4. You can read, program or erase (EEPROMs only) your S5 memory module with the EPROM functions of the STEP 5 software. 5. Extract the S5 memory module. 6. Close the EPROM functions of your STEP 5 software. User manual is here. Have a nice day J. |
