6/21/2023 11:20 AM | |
Joined: 2/17/2020 Last visit: 4/21/2025 Posts: 1250 Rating:
Hi, I believe that you are looking for the following application example: WinCC Audit Trail Filter (filtering the operator actions on the SIMATIC Panel) Another option would be to use the Audit Viewer on a PC to evaluate the Audit Trails generated by the panel: GMP-compliant Configuration with WinCC Comfort/Advanced, WinCC Audit and HMI-Panels Hope that helps! |
A rating will be well appreciated. |
