6/19/2018 8:16 AM | |
Joined: 5/16/2014 Last visit: 9/12/2022 Posts: 7298 Rating:
Hello bibak,
PS: If this post did really help you, you may use the Rate-button |
8/31/2018 8:38 AM | |
Joined: 2/11/2015 Last visit: 10/21/2022 Posts: 425 Rating:
Hi Bibak, Maybe you could save on PLC only one column Liters, says array of 2000 records, and on the WinCC do the calculation in order to get the volum. |
10/18/2018 2:46 PM | |
Joined: 7/1/2013 Last visit: 1/11/2023 Posts: 70 Rating:
I ti a little bit confusing. Liter is unit for volume. m3 = 1000 L (Liter) You should be able to store 2000 double words (real) to data block, it is 8003 bytes, and as far as I know DB size can be more than that. Mayeb you clould use separate data blocks for every "column". Best regards. |
