5/4/2020 10:07 AM | |
Joined: 2/7/2018 Last visit: 2/3/2023 Posts: 176 Rating:
Hi, you can integrate the error codes of a SINAMICS drive into a HMI project via XML-parser. Therefore you need a xml-list of the SINAMICS S210. If you use a SINAMICS S210 with firmware V5.1 SP1 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109758780 If you use a SINAMICS S210 with firmware V5.2 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109762805 If you use a SINAMICS S210 with firmware V5.2 HF6 you can find the xml-list at the chapter “List of faults and alarms” at following URL: https://support.industry.siemens.com/cs/ww/en/view/109773739 How to import the error messages in a HMI-project you can get information at following application example: https://support.industry.siemens.com/cs/ww/en/view/77467239 Best Regards, |
