1/6/2014 2:03 PM | |
Posts: 311 Rating:
Hello all, Is it possible to read a tag within a faceplate (the tag is not configured within the faceplate) ? Reagards Per Olof |
1/7/2014 6:02 AM | |
Posts: 515 Rating:
hi, Add an i/o field in the faceplate and assign it a tag. is this what u need/meant?
1/7/2014 1:09 PM | |
Posts: 1299 Rating:
Hello, you have to declare tags inside the faceplate and "connect" them with the tags outside the faceplate using the interface of the faceplate. K!ke |
