8/9/2011 4:19 PM | |
Posts: 10 Rating:
Dear Expert, I need to read data record of analog input channel 0 (Flow Meter) of Hart AI module with logical address IW512 using SFC 58 & SFC 59. I am getting a reply in Byte 0=B#16#03 of DB 109 & sometimes Byte 0=B#16#07, Byte 1=B#16#52, Byte 2=B#16#84. Please help I have attached my program & HW configuration for proper understanding of my problem.
AttachmentPROG_CONFIG1.pdf (1038 Downloads) |
8/9/2011 10:38 PM | |
Joined: 1/28/2009 Last visit: 6/10/2023 Posts: 6807 Rating:
Hi OSNAT Please take care of these limitations: What restrictions are there for active jobs when communicating with SFC 58 / SFC 59 and SFB 52 / SFB 53 via PROFIBUS DP and PROFINET IO? Note SFC 58 "WR_REC" is used to write the data records
To get the meaning of data records in a specific module, you should check the manual of the module(AI) like attachment and also arrange e.g UDT as shown in attachment for frequent use. Regards Attachmentsfc59.zip (1083 Downloads) |
8/11/2011 1:35 PM | |
Hi Take a look at SIMATIC ET 200M distributed I/O device HART analog modules for more description on Data record structure on HART module and some programming tips and samples. Best regards |
