11/23/2012 7:21 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating: (715)
Hello, See attached PDF. Regards, Marcjan Attachmentdiagn.pdf (163 Downloads) |
Problem solved? |
11/25/2012 2:46 AM | |
Joined: 9/27/2006 Last visit: 9/13/2024 Posts: 12282 Rating: (2683)
Hello Alex; One suggestion: try PIW 274 instead of IW274. It seemsyou are trying to reach an address that is outside of the input process imagetable, in which case you should use peripheral addressing: PIWxxx for inputs, PQWxxx for outputs. For more details, please refer to the following FAQ: Where and when do you need peripheral addressing? Hope this helps, Daniel Chartier |
