12/10/2018 9:52 AM | |
Posts: 5 Rating:
Dear User I am using CP 341 RS232C for fetching data from Foundation field bus device. FG200. I am using S7 300 PLC. In my program i have used block P_REC_RK FB7 for receiving the data. I have used this block directly in OB1. CP TX and RX Leds are blinking indcating that it is sending and receiving the data. If i remove Rs232 Cable immediately CP Shows SF Indication. But I am not able to receive data in the defined DB in P_REC_RK. I am not getting any error in block. Status indication is showing 16#0000. i am not clear wither program is correct. If it is correct why i am not getting reading. If it is not correct i would like to know the procedure for going in correct way. I am attaching the word file of Hardware configuration and Blocks Regards Tapan Attachmentcp 341 Rs232 Comm configuration.docx (248 Downloads) |
