5/26/2014 10:21 PM | |
Joined: 1/28/2009 Last visit: 12/28/2022 Posts: 6785 Rating:
As Juergen already has mentioned , this type of notation is for SCL.I only suggest working on SCL in case of arrays (inside DBs),Read more HERE for a sample codes for both SCL and STL.Please note, how working on SCL is convenient and easy!
But for STL, your project are vulnerable to structure of the DB.Any change in the structure of DB , destroys all your great work and time spent on your calculation! To avoid repeating your work again and again use SCL! But to do it in STL,you should know :
It is your choice to select! |
5/27/2014 10:55 AM | |
Posts: 2 Rating:
Thanks guys, for pointing me in the right direction. I used SCL and it worked fine! thanks again! |
2 thankful Users |
