7/6/2012 10:56 AM | |
Posts: 6 Rating:
Hi, Attachmentblock.zip (48 Downloads) |
Last edited by: small1978 at: 7/6/2012 2:29 PMLast edited by: O_Moderator at: 7/6/2012 11:01 AMnew subject after splitting from /tf/WW/en/Posts/6064#top |
7/6/2012 3:40 PM | |
Joined: 10/7/2005 Last visit: 3/26/2025 Posts: 3043 Rating:
Hello small1978 you need to use the I/O address of your CP343-1 as the CPLADDR address parameter of PNIO_RECV (or PNIO_SEND for that matter). Everythingelse you need to know about usage of PNIO_SEND and PNIO_RECV can be foundin the FAQ below (note too that using F1 on the FC's itself will give you the context sensitive help on them): How do you program communication blocks FC11 and FC12 for the PROFINET IO controller? I hope this helps P.S: It is permissibleto give theseFC's a different number. |
Cheers |
