5/16/2014 12:07 PM | |
Joined: 9/23/2005 Last visit: 1/27/2023 Posts: 4176 Rating:
Hi, if you use the PID_Compact/ PID_3Step, you don't need to set manually the execution time. To get the time interval you can use: - offlinke know how (if you create the block you know the time that it has). - OB internal (temporary variables - sinse you use nom optimize mode) - An example of these methods are show in http://support.automation.siemens.com/BR/view/en/87668055 |
5/16/2014 1:45 PM | |
Posts: 14 Rating:
Can anyone confirm that RT_INFO works with the PLC simulator?? We cannot get it to work with the simulator and do not have a real cpu here.. |
5/19/2014 12:42 PM | |
Hi, really sory for the mistake The RT_INFO just measure the runtime, not the time interval. I correct the open post. An example how to measure it stay on http://support.automation.siemens.com/BR/view/en/87668055 |
Denilson Pegaia |
