6/15/2017 1:44 PM | |
Posts: 19 Rating:
hi... thanks what would be the "INDEX" value in the RD_REC block for the parameter r0031 |
6/15/2017 2:00 PM | |
Posts: 1529 Rating:
Which ones have you tried? 0 would be a good place to start. |
3/9/2018 12:42 PM | |
Joined: 5/12/2006 Last visit: 1/24/2025 Posts: 22508 Rating:
Hello, now you can read the value directly from the IO Adress 114. Regards Christoph |
7/25/2018 1:02 PM | |
Joined: 4/23/2010 Last visit: 11/23/2024 Posts: 8092 Rating:
Hello, Please check SINAMICS V: Acyclic communication between SIMATIC S7-1500 and SINAMICS V90 via PROFINET application example, Documentation , chapter 5. HTH. |
