1/5/2012 3:16 PM | |
Joined: 5/27/2009 Last visit: 2/10/2022 Posts: 122 Rating:
Hi, when i worked with Data Base Connections i did it with WinCC V7.0 SP1 using Visual Basic Scripts i haven't used the WinCC version you told me i don't know if there ir also an Option for making scripts. But anyway i send u an example. AttachmentScriptBD.zip (2192 Downloads) |
7 thankful Users |
5/25/2012 10:28 AM | |
Posts: 3037 Rating:
Hello, You can use this tool in the following FAQto export archiv data to a csv file. Export of WinCC / CAS Archive Data using the WinCC OLE DB Provider Tweety |
1/28/2021 1:40 PM | |
Joined: 8/18/2014 Last visit: 1/7/2023 Posts: 58 Rating:
I hope it will work. Thanks |
