9/7/2010 9:27 AM | |
Joined: 10/7/2005 Last visit: 7/25/2024 Posts: 3011 Rating:
Hello Marcio Camargo am I correct in assuming that your variable "leitura_Ref_Princ" is of typeINT or DINT and you simply "MOVE" it into a TEMP variable of type REAL? If so, it explains your problem and you will have to convert thevaribale from an INT (or DINT) to REAL rather than doing aMOVE (a MOVE does only a simple "copy/paste" of the original value). To do so, you'll find "I_DI" (Integer to Double Integer) and "DI_R" (Double Integer to Real) conversion blocks in the "Converter" section of your programming elements. I hope this helps |
Cheers |
