7/4/2012 1:21 PM | |
Posts: 3037 Rating:
Hello, If you use tags of recipe in IO Fieldin the same screen as the recipe view, then you can synchronize the tags in IO Field and in the recipe view with the parameter "Direct synchronization". See the screenshot. You can find more about recipe in the following manual in chapter 9.5. WinCC Advanced V11.0 SP2 Tweety |
