11/17/2008 8:34 AM | |
Posts: 3 Rating:
Problem:Almost every time i try to acces WinCC i get error message REBOOT.After i reboot it works well.Is it a problem in a Windows server 2003 settings or is it something else?
Attachmentreboot.zip (31 Downloads) |
11/18/2008 2:20 PM | |
hello mrki do you get before any error-messages. PCS 7 has detected an error atitself and need a restart. With this message only, it´s difficult to help you.Tell me more. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
11/18/2008 2:53 PM | |
Posts: 3 Rating:
hi.i do not get any message before.thats it.when i open wincc this appears.thank you |
11/20/2008 10:58 AM | |
Hi, you should check your Windows EventFiles and your WinCC Diagnostic Files to find out the Task which is the reason for this error message. If the task you find out is a WinCC/PCS7 task or if you do not have any idea you should collect the files mentioned above and contact the hotline. If the task is a Windows task or a task of a additional program you should check the installation of this task (reinstall). Cumulus |
