7/24/2015 11:19 AM | |
Joined: 10/17/2011 Last visit: 7/19/2022 Posts: 148 Rating:
Hello Sir, I want to send and receive data to PC based software using UDP protocol of s7-1200 plc. Please share, How to configure the TCON,TUSEND AND TURECV Blocks for the same. What PC parameters I should know for this communication? Thank You. Damayanti
Last edited by: Min_Moderator at: 7/24/2015 4:11:16 PMNew subject after splitting |
7/24/2015 11:50 AM | |
Posts: 160 Rating:
Hi, take a look at the file I attached on this post. Be careful thou, because you will have to make some changes regarding TCON_PAR parameters, maybe 2-3 of them... go to online help for TIA where all these stuffs are perfectly explained. In case you have some troubles, post all pictures which should help us understand your problem. Janko AttachmentPossible Config.DOCX (1186 Downloads) |
