10/2/2017 5:13 PM | |
Joined: 2/5/2013 Last visit: 10/14/2024 Posts: 288 Rating:
Dear Sirs, why in a ANSI C script reading a datetime value from an internal tag and saving it in a Recipe result in a wrong time? If I copy the datetime field back to an internal tag the time is correct, but in a recipe view, its wrong. Last acces datetime is correct instead.
Stored result are forwarded by an hour. Time settings on the PC are correct. Why the readed value from the archive are correctly diplayed in the internal tag? Still hoping in a reply, BR ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/6/2017 10:26:14 AMNew subject after splitting |
10/10/2017 9:30 AM | |
Hello Summer88 you can use this one: https://support.industry.siemens.com/cs/ww/en/view/24019500 Bye Murof |
