9/16/2020 1:16 PM | |
Joined: 4/13/2019 Last visit: 1/16/2022 Posts: 1 Rating:
Hello ixo65, I'm doing a the same project but with 24VDC Logo 8 and I also have the same question about the wiring for the inputs. I will do all the automation with low voltage and I will use interface relays for the outputs. I will need to install a multi-core cable for the inputs inside the conduits in the wall and I would like to know what is your recommendation for the minimum cross section of the cores in order that I can have a light and stable installation. Many thanks in advance! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/09/2020 12:31:41New subject after splitting |
