5/15/2009 9:22 PM | |
Joined: 3/18/2009 Last visit: 2/8/2022 Posts: 306 Rating:
Yes, for H-systems with WinCC you have to use named connections. In NetPro you need to form a S7 fault tolerant connection Not only that, you will also require a CP 1613 for your PC (Normal LAN port of the PC, i.e "IE general" does not work with S7-fault tolerant connection)A beautiful explanation for same from one of thepostby J_bell.
Also you need a S7-Redconnect license on your PC. |
