4/30/2014 12:25 PM | |
Posts: 17 Rating:
hello my problem is i dont know how the s7 1200 send date to a s7412-5h(2PLC) in the same timebest regards
4/30/2014 12:43 PM | |
Posts: 1368 Rating:
Perhaps it would be sensful, to look at these documents to know al liitle bit more about H-Systems http://support.automation.siemens.com/WW/view/de/82478488 http://support.automation.siemens.com/WW/view/de/90885106 /tf/WW/de/Posts/96652 |
4/30/2014 1:26 PM | |
Posts: 17 Rating:
Thank you very muchPittiplatsch so i can use s7 communication between 1200 and one s7400h(Master or Reserve)? best regards |
4/30/2014 2:07 PM | |
Posts: 17 Rating:
Thank you very muchPittiplatsch i have to try thes7-communication with PUT/GET in the one plc s7400h (master) port in/io but if this CPU is in stop the other plc (Reserve) will be (MASTER) and she can also read the date from the cpu 1200 ? best regards
4/30/2014 2:59 PM | |
Posts: 1368 Rating:
Hello, The Master and Reserve PLC communicate each other via sync module and change data. in case of error, the other PLC takes over the communication without data loss. Have a look here http://support.automation.siemens.com/WW/view/de/90885106 |
