3/6/2020 3:00 PM | |
hi, which OPC UA Server do you use? from WinCC Professional of from the S7-1500H? regards, |
FCK WAR! |
3/7/2020 2:16 PM | |
Joined: 8/11/2018 Last visit: 7/22/2022 Posts: 9 Rating:
I want to use OPC UA server from WinCC Professional. But write access to data can not be restricted. |
3/12/2020 10:42 AM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello Alexander Diev perhaps this one leads into the right direction: https://support.industry.siemens.com/cs/ww/en/view/99923489 Bye Murof |
3/12/2020 2:46 PM | |
This works with Simatic Net from V8.1 to V12. In versions 13+ redundancy option is not present in configuration. |
