3/16/2010 9:05 AM | |
Joined: 10/7/2005 Last visit: 3/26/2023 Posts: 2962 Rating:
Hello Fiec. Exp. that would be a "it's not possible" answer from my side (or at least it isnot an offically supported configuration a far as I'm aware). Going by your question, it seems that all that you are interested in is to achieveredundancy of theProfibus network. If so, you coulddo so by using OLM (OpticalLink Modules) and create a Fibre OpticRing with them which will give you redundancy (more about this can be found in THIS OLM manual). I hope this helps |
Cheers |
