5/26/2011 10:41 AM | |
Joined: 2/1/2011 Last visit: 10/4/2021 Posts: 185 Rating:
Dear Sir, |
5/26/2011 12:43 PM | |
Joined: 7/2/2008 Last visit: 3/14/2023 Posts: 928 Rating:
Dear ashishmishra,
There is more than a way to link your HMI with redundant system of CPU 315-2 DP. The simplest way will be using MPI ports of the CPU and using an HMI with MPI interface. Please tell us more about your configuration and your HMI available interfaces so we can help you better. There's no chance at all. It may work if the "HMI" is a pushbutton panel (i.e. has a GSD file). Otherwise, no chance at all. Best regards. H-H |
5/26/2011 7:20 PM | |
Joined: 2/6/2009 Last visit: 3/10/2023 Posts: 932 Rating:
Hi, Here is the manual for connecting the HMI panel with H-system with and without repeater. This manual gives the detail about connecting the HMI with H-system, I think you can try the same with R-System.
AttachmentHMI.zip (69 Downloads) |
_______________________________________________________________ |
