7/4/2011 4:48 AM | |
Posts: 93 Rating:
So.. if the ch1(profibus), ch2 and ch3(fiber channels) are in yellow indication communication should establish.. remote i.o panel's modules should communicate... even if the ch2 level and ch3 levels are in red indication.... is this perception right? |
7/4/2011 9:40 AM | |
Joined: 12/2/2010 Last visit: 4/2/2024 Posts: 61 Rating:
Hi... You are correct. Green Indication:Signal strength is Good. YellowIndication:Signal strength is Ok. Red Indication: Signal strength isBad. CH1(Profibus):-Green. CH2 & CH3 :-Yellow. I also used lot of OLMs in my projects iwas seenyellow Indication only in CH2 and CH3.Still the remote IOs working without any problem. |
Regards \ Sankar |
7/4/2011 7:43 PM | |
Posts: 93 Rating:
Thanks Mr sankar. can u pls give me ur number??????? |
