10/13/2020 9:24 AM | |
Joined: 8/6/2008 Last visit: 2/4/2023 Posts: 36 Rating:
Hi Online-Tech The solution with port forwarding is working to access the S7-1200 PLC. However when i try to login to the PLS, providing userid/passw the access fails. The plc is trying to setup a secure connection! How can we solve this so that remote access is working via port-forwarding and dynamic dns. Best regards, Fabrizio ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/13/2020 13:54:41New subject after splitting |
10/13/2020 2:54 PM | |
What do you mean by "access fails"? Does the browser pop up a message about secure connection certificate problems? Or does the PLC reject the connection?
science guy |
10/13/2020 7:25 PM | ||||
Joined: 3/28/2015 Last visit: 2/5/2023 Posts: 698 Rating:
Hello, Can you explain your issue in detail? 1-Enable the web server on the CPU 2-Port forwarding in the router setting"Remote side":
"CPU IP Address" 3-Office PC"Local side": http://domain"Remote side":102 not https://domain "Remote side":102 |
Eng.Mohamed Ibrahim |
1/28/2023 7:23 PM | |
Joined: 8/21/2020 Last visit: 1/28/2023 Posts: 1 Rating:
You solved this problem? |
