1/13/2011 10:11 AM | |
Joined: 9/23/2005 Last visit: 1/30/2023 Posts: 4177 Rating:
Hi, there many ways to do it. One way is to use WinCC flexible and run the same HMI project in the PC, as runtime system. Other way is to use Sm@rtAccess or Sm@rtService to make a telecontrol of the HMI. |
Denilson Pegaia |
1/13/2011 10:42 AM | |
Posts: 6 Rating:
Thanx for your info... |
1/14/2011 12:21 AM | |
Joined: 5/4/2009 Last visit: 11/9/2022 Posts: 906 Rating:
What about the 'Webserver", isn't usefull in this case? |
Aim Higher |
1/14/2011 10:29 AM | |
Hi, Webserver for HMI is possible with WinCC flexible and Sm@rtAccess or Sm@rtService. for S7-1200 Webserver will not realeased at the corrent TIA version... |
Denilson Pegaia |
1/14/2011 3:28 PM | |
I have learned that it will be availble with TIA Portal V11 |
Aim Higher |
