4/12/2006 9:53 AM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, siemens has a new TS Adapter which can use PPI. Under this link you can find the manual => http://support.automation.siemens.com/WW/view/de/20983182/0/en Here a onother link with infos about TS Adapter => http://support.automation.siemens.com/WW/view/de/1096710 I did not usea TS Adapter at time, but i think with this information you can realise your problem. greetings |
4/12/2006 1:12 PM | |
Hi, i have search for more info and the only link that i found are this. => http://support.automation.siemens.com/WW/view/en/13008937 But the problem are, that you could not use a OP7 in conjunctionfor teleservice! In the manual there are only a description for WinCE Systemsand a OP3. The cause are, a download to aOP7 are only possible with a "seriell transfer". (WinCE could be downloaded via MPI/DP) Sorry, butit seems that you could not do a update for a OP7 via modem. greetings |
