12/8/2017 7:48 PM | |
Joined: 11/6/2017 Last visit: 1/16/2023 Posts: 27 Rating:
Hello Experts, I have to remotely access of HMI on conventional PC. I need your opinion, how to do this job. The project is built in TIA Portal V13 and hardware is PLC and TP1500 Comfort Panel. Thanks & Regards ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/11/2017 12:49:37 PMNew subject after splitting |
12/12/2017 2:20 PM | |
Hello bilalifc you should check the option -> SmartServer look in this FAQ: https://support.industry.siemens.com/cs/de/en/view/109476153 Bye Murof |
