8/19/2009 5:15 AM | |
Posts: 2 Rating: (0) |
I need to take out/remove the output card (6ES 441-4UA12) from S5-155 using CPU928-A.How to delete the confrigution from the system ? |
8/19/2009 12:35 PM | |
Posts: 76 Rating: (8) |
Hi, There is no configuration for S5 cards. You need to delete the program blocks (lines) which access the cards! Good luck! |
8/19/2009 12:48 PM | |
Joined: 10/7/2005 Last visit: 10/4/2024 Posts: 3024 Rating: (1054) |
check too if you have a DB1 in your CPU. If so, it contains the so called address list and you will have to remove the addresses for the DQ card (that you intend to remove)from DB1. Here is the link to the 928(A) manual whichI trust will come in handy. AG S5-135U CPU 928 Programming Guide |
Cheers |
8/24/2009 2:54 AM | |
hi, Fritz, Thank a lot, |
