6/5/2008 5:51 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, normaly i use the function under "Edit > Find in project..." Filter --> Find what ... "Tag" Reference -> not use by... --> Find now! After then you can select all tags which you are want and delte it. Or look under this link -> http://www.automation.siemens.com/microsite/wincc-flexible-easy/index_en.html --> Experience --> Tag handling --> Tips and tricks ---> start film ---> forward to the middle of the film! (there you will find a sample for "search in the project") regards, |
6/6/2008 9:58 AM | |
Joined: 2/12/2008 Last visit: 11/18/2022 Posts: 68 Rating:
Tankyou for the accurate ansewer. Best regards |
4/11/2017 2:50 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4839 Rating:
New question published by fiah is split to a separate thread with the subject Remove all unused tags from s7 TIA V13 Project . Best regards |
