4/29/2014 7:24 AM | |
Joined: 4/5/2006 Last visit: 8/13/2023 Posts: 642 Rating:
Hello, is it faulty? You can partially use new panels with 6AV6671-8XJ00-0XA0 and 6XV1440-2A____. The easiest way is to use an other OP25 (when the reason for replacing is a fault). The other way is a complete upgrade. Have you the Protool file? Regards André Räppel --------------------------------------------------------------------------------- www.raeppel.de work faster withinnovative PLC-Tools |
5/15/2014 12:37 AM | |
Joined: 2/3/2011 Last visit: 2/6/2025 Posts: 348 Rating:
I got the protool file and an op25 panel from other machine. Thanks. |
5/15/2014 1:34 AM | |
Joined: 5/28/2008 Last visit: 2/12/2025 Posts: 4518 Rating:
Hello, The suitable cable is6XV1 440 - 2K... Please see the attachment. It's phased out product. But you can make it yourself. Here's bellow its pin assignment. What is the serial cable assignment for transferring the configuration to an RMOS operator panel? AttachmentProjekttransfer_e_C1.pdf (164 Downloads) |
Ayman Elotaify |
