10/12/2008 12:54 AM | |
Posts: 12 Rating:
I need make convert s5 into s7,but I want to know which module can replace wf725 in s7 |
10/12/2008 8:20 AM | |
Joined: 9/27/2006 Last visit: 5/28/2023 Posts: 12024 Rating:
Hello kongfu; The WF 725 is described (on the web) as a 3-axis positionner module. In the following link, you will find tdifferent FMs used with Siemens S7 PLCs. You could look at the details for the FM 351/451, and the FM 453, depending on the type of motor you wish to control: https://www.automation.siemens.com/simatic/regelsysteme/html_76/produkte/sb-f_baugruppen.htm?HTTPS=REDIR Hope this helps, Daniel Chartier |
10/12/2008 10:17 AM | |
Posts: 12 Rating:
Hi,Mr dchartier,thanks for you help Best regards, |
