9/28/2016 10:32 AM | |
Joined: 11/14/2008 Last visit: 5/6/2024 Posts: 504 Rating: (22) |
Check this link for the requirements to change your current project to TIA Portal and also look how to use Migration tool for TIA But first of all check if your system is TIA ready with the TIA Portal Readiness Check Tool with this tool you can check if it's possible to use every equipment (DI-/DO-cards/CPU/CP/...) that is currently in your system with TIA. One of the obstructions will be that cards etc older than October 2007 will not work (because it's not supported) . Easy to check with TIA Portal Readiness Check Tool... Regards, |
9/28/2016 10:59 AM | |
Joined: 7/9/2015 Last visit: 8/30/2024 Posts: 3943 Rating: (585) |
Hi, you can also check if your actual available HW is compatible with this Excel sheet in the following entry: Which devices and modules are supported by STEP 7 Professional and WinCC Professional in the TIA Portal?Regards, Towome |
9/28/2016 11:26 AM | |
Joined: 7/28/2016 Last visit: 6/10/2024 Posts: 6 Rating: (0) |
Thanks for the fast answers. I really need to know what type of new CPU can replaced the old 314 CPU |
9/28/2016 1:49 PM | |
Hi ClausHenneberg, Please first check if you'll have issues on functionalities (software) with this tool. You'll need to upgrade to a new S7-300 Compact PLC. Are there any technological functions (of IFM PLC) used ? If so , they will need to be adapted... |
