1/17/2014 11:27 PM | |
Joined: 4/5/2006 Last visit: 8/13/2023 Posts: 642 Rating:
Hello, directly replacement is not possible. The easiest way is to use an other OP17. 6AV3617-1JC00-0AX1? I have it in stock. Regards André Räppel --------------------------------------------------------------------------------- www.raeppel.de
work faster withinnovative PLC-Tools |
1/24/2014 9:50 AM | |
Hello, maybe its possible to connect new HMI's via profibus to IM308C. Regards André Räppel --------------------------------------------------------------------------------- www.raeppel.de
1/25/2014 12:56 AM | |
Joined: 10/12/2006 Last visit: 2/3/2025 Posts: 206 Rating:
sps-concept have right, because the AS511 baud is 9600... it is very slow. regards Zenta |
1/25/2014 1:14 PM | |
Joined: 5/28/2008 Last visit: 1/29/2025 Posts: 4518 Rating:
Hello,
Hope this helps. |
Ayman Elotaify |
1/27/2014 8:24 AM | |
Posts: 5 Rating:
Thanks for the support. It's much appreciated.
I think I'll go with 177b. |
1/27/2014 10:28 AM | |
Hello, then you will have problems with the area pointer for picture-no if it is used. You must alsoedit your S5-program. Regards André Räppel --------------------------------------------------------------------------------- www.raeppel.de
