1/30/2007 2:47 PM | |
Posts: 3149 Rating:
Hi you could use panels of 270 series or panels of 170 series (TP/OP177 PN/DP)- I´d recommend the 270 series. As software you´ve to order WinCC flexible, for migrating your protool project you got to open your protool project with WinCC flexible and then big parts of your former engineering can be taken into WinCC flexible. I would use Ethernet for connecting your panels to your PC (and for downloading your engineering as well). http://support.automation.siemens.com/WW/view/en/11376409 http://support.automation.siemens.com/WW/view/en/20681208 http://support.automation.siemens.com/WW/view/en/13336639 http://support.automation.siemens.com/WW/view/en/22726112 nemo |
