11/6/2012 10:07 AM | |
Posts: 376 Rating:
Hello RasmusBoomer, I think the recommendation of member babbelfish1 is a good way. Perhaps the problem is known to the Technical Support for SIMATIC and you get a solution for the problem. The access channels find you here. http://support.automation.siemens.com/WW/view/en/31045710 I still would be interested in the following. 1. Have you edited this SCL-FB with this version STEP 7 V11 SP2 Update 5 newly? 2. Does this concern a particular SCL-FB or have youthis problem with every SCL-Block? 3. Did you already have this problem before the installation of Update 5, too? I think this information will be interested also the Technical support. Please write the answers to these questions also into your Support Request. Many Thanks Best regards Azteke0110 |
