8/19/2014 3:29 PM | |
Joined: 11/21/2007 Last visit: 3/16/2025 Posts: 2326 Rating:
Hello Kashir OSM TP 62 has been Cancelled. That means it is still available as a spare part ( Although at a higher price and longer delivery ) for existing systems. Pl contact your Siemens Contact partner for the same. New systems should be re-engineered with appropriate SCALANCE Switches from the Series X-200 / X-300 / X-400. Pl See the Discontinuation update : Optical Switch Modules OSM and Electrical Switch Modules ESM to Be Phased Out There is no exact replacement for OSM TP 62 although you could consider using ( Depending on how many ports are in use in your system: SCALANCE X204-2 ( 4x RJ45 + 2 x BFOC ) or SCALANCE X212-2 ( 12xRJ45 + 2x BFOC ) Digital Inputs ( If used ) need to be handled separately. Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
8/22/2014 8:05 PM | |
Joined: 10/24/2012 Last visit: 3/21/2025 Posts: 311 Rating:
Thanks Navang its really helpful.......
Kashir Saeed. |
