2/19/2011 2:38 PM | |
Posts: 31 Rating:
our machine has PCU20 but we want to replace this with PCU50. Is it possible? If yes, how to do this? best regards Splitted from how to prepare new PCMCIA card to work with CCU?. |
2/24/2011 3:04 AM | |
Joined: 10/17/2007 Last visit: 11/29/2023 Posts: 3734 Rating:
====================== hi, it is easy. just remove pcu20,and install pcu50, more important cableis MPI. that's it. as your m/c using pcu20, almost everything(NC/PLC DATA, part prog )in NCK memory. after you replacing w. pcu 50, making a backup of abovedata. I did this many times per day. on my demo. 840D only one thing i did not try. before you replacing ,make backup w. winpcin the user alarm text to you ext. PC (using tape format).then print it out. I think you should edit this on pcu50 HD, by yourself. REF* Doconweb.840D alarm text PCU50/MMC103........ try it and good luck. |
Last edited by: nulizhang at: 2/24/2011 3:07 AMusing winpcin tape format in order to print when done If you like my comments please |
2/26/2011 7:18 AM | |
Posts: 31 Rating:
Thanks to All I am sending the full detail of macine (Attached file). Please download and check the posiblity and all steps to replace the PCU20 with PCU50. AttachmentMachine Specification.zip (196 Downloads) |
1/11/2012 1:20 PM | |
Posts: 22 Rating:
Thats because it was a comment, not a question ;) |
