10/25/2012 11:35 PM | |
Joined: 7/2/2008 Last visit: 3/19/2025 Posts: 928 Rating:
HelloSathishkumar Namasivayam, Unfortunately there's no direct solution for redundant I/Os in Profinet. Although Siemens has released the400H CPUs V6that supports ProfinetSystem Redundancybut still this Profinet solution will not work for redundant I/Os for a reason I do not know. However, you can make a software solution for RED IO based on Profinet. You can read more in chapter 13.5 (Other options for connecting redundant I/Os) in the400H manual. I just let you know that such solution exists but If I were you I wouldn't go for it not because it's a hell of work but because 2 IM153-2 is better and gives you more availability than a single IM153-4. Best regards, H-H
