9/29/2014 9:51 PM | |
Joined: 2/26/2013 Last visit: 2/22/2024 Posts: 48 Rating: (0) |
Thank you for your help. But I don't have simatic card, so is there any other way to reset cpu? best regards |
9/30/2014 12:27 PM | |
Posts: 784 Rating: (52) |
"Reset to Factory Setting"
9/30/2014 1:07 PM | |
Hello, If"Reset to Factory Setting "not successed, You should need MMC. Kindly inform us with the result. Best regards........
9/30/2014 2:43 PM | |
Hello Wago, I really appreciate your help. I tried with factory reset and still require password. Tomorrowwould siemens support sendme a mmc that suit to cpu 1200 family. I'll reportresult tomorrow... best regards |
10/1/2014 12:17 PM | |
Hello, I just inform you that the reset was successfull. With a right mmc card the job is done in the moment. But, as somebody told in another thread: Do not upload a password-protected program with an empty password! Best regards |
10/29/2014 10:24 PM | |
Posts: 81 Rating: (0) |
I am facing the same problem, I tried with normal 32GB sd card. I didn't work, So we must use siemens memory card for this process???? |
Last edited by: Min_Moderator at: 10/30/2014 11:17 AMYou will find the original thread here: /tf/WW/en/Posts/116684#bottom Last edited by: pavans at: 10/29/2014 10:24 PMLast edited by: pavans at: 10/29/2014 10:24 PMLast edited by: pavans at: 10/29/2014 10:24 PMLast edited by: pavans at: 10/29/2014 10:24 PM |
10/30/2014 3:16 PM | |
Joined: 8/31/2010 Last visit: 4/14/2024 Posts: 1509 Rating: (222) |
Hello pavan, Ensure you are using at least any of the below mentioned MC. *6ES7954-8LC02-0AA0(4 MB) *6ES7954-8LE02-0AA0(12 MB) *6ES7954-8LF02-0AA0(24 MB) *6ES7954-8LL02-0AA0(256 MB) *6ES7954-8LP01-0AA0(32 GB) |
Last edited by: Ganes10 at: 10/31/2014 5:43 AMmissed the 4 MB and 12 MB cards Like it? Rate it! |
9/17/2018 6:00 PM | |
Posts: 3 Rating: (0) |
can we not just use a normel SD card? |
