4/16/2009 10:39 PM | |
Posts: 2661 Rating: (279)
Hi Hany, There is no simple formula for calculating the response time. It involves much work depending on the complexity of the configuration. It is very important to know the exact part numbers. The newer version of every component has better response. To give you an idea attached is a manual which addresses the performance data of WinCC 6.2. The best approach for you is to contact the local Siemens sales person. Regards AttachmentPerformance.pdf (164 Downloads) |
4/18/2009 10:52 AM | |
Posts: 2 Rating: (0) |
thanx my expert |
